Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Anonymous Posted on Aug 15, 2013
4gb shows 2mb how to repair it - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Brian Sullivan
Level 3:
  • Kingston Master 27,725 Answers
  • Posted on Aug 15, 2013
Brian Sullivan
Kingston Master
Level 3:
Answers
27725
Questions
Helped
5664401
Points
79191
Click start control panel Administrative tools Computer Management Disk Management
right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive.
You might get best results ticking in one box the returning after it has finished then ticking the other box.
It might take some time depending on the size of your disk but be patient.
Click start click to open on my computer you should see your usb drive F: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Click start click on my computer you should see your USB Drive right click then select format
another way is to control panel administrative tools computer management disk management right click on your USB Drive select format
usb chkdsk utility
then you restore it to its default status
restore defaults
In XP
you might have to alternate doing this repeatedly until you find the sequence to get the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this post a reply
I have a HP dc7600 small form pentium4HT 3.4 GHZ with 1GB of Ram. What type of RAM do i need to max this machine out safely?
Memory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 4GB
Slots: 4
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
icon_note.gifAlthough the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.When using PC2-5300 parts the maximum memory is 2GB. When using PC2-4200 the maximum is 4GB.
3helpful
2answers
I purchased a Coby 4 GB MP3 Player. It stated that it will hold 2000 songs but became full at 500. Did I download incorrectly?
When it says 2000 it means that it can hold 2000 songs, considering that each song is 2 MB. So, 2MB * 2000=4000MB=4GB.
So your songs were much larger than that.
2answers
My windows system is windows 7 professional ive even checked it on xp still it shows 2mb instead of 8gb why?
if you have 8GB RAM you have to use a 64 bit version of the operating system to recognize it correctly.
Purchase 5 new verbatim 4gb when i plug it into pc the system found new hardware and installed . then it allow me to used two of the drive. when i plug it in the pc a msg appear, u need to format the disk...
You have to format the drives. If you put data on the drives using computer 'a' whos OS is MacOS and then you put the same Drive into computer 'b' which has windows, it may not recognise the file system/structure.
1helpful
Remove the write protection from the volume
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
Sir, I have TDK 4 GB Pendrive. I was formated some
Dec 14, 2009 • Vacuums
1helpful
I deleted all my songs on my 4gb mp3 player and have less storage
there could have been any virus so format the mp3 player and also scan it with antivirus .
Can ixus700 upgrade to use 4gb memory card?
The ixus 700 is only specified to be compatible with SD memory cards (and MMC cards). The protocol for SD cards only covers up to 2MB. Cards of higher capacity are the SDHC (high capacity) protocol, but this protocol did not exist when the ixus 700 was introduced. As far as I can tell, there is no way to upgrade to be compatible with the newer protocol.
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
