All my photos are coming out with coloured lines all over them?
SOURCE: multiple colour lines appearing in d40x
Can you upload a photo that shows this? You can just take one set to low resolution so the file size isn't too big.
SOURCE: I have purchaced nikonL22 on 10th May,I observed
It shouldn't do that, as its new I'd suggest you take it back to the dealer/vendor, request they demonstrate to your satisfaction. If they can't request a replacement or refund under warranty.
SOURCE: My photos come out with
When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
CCD (Charge Coupled Device): one of the two main types of image sensors used
in digital cameras. Some symptoms of a defective CCD
include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image).
If seen on both your pc monitor as well as the camera's LCD then it's
likely a CCD issue and it's no wonder that it will be more expensive
than buying a new digicam. This is why you need to be exceptionally
careful when taking care of your camera since most are uber sensitive to
being damaged by the slightest miss-handling.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs
Hope helps.
