Memorex (32025536) DVD-RW Storage Media Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DVD disc lable 4.7GB, but it has only 4.38GB capacity
Is there anyway that we can reformat it to a full capacity?
Anonymous
Level 2:
  • Expert 272 Answers
  • Posted on Apr 06, 2009
Anonymous
Expert
Level 2:
Answers
272
Questions
0
Helped
61513
Points
860
The answer is clear .. no, you can not.
Easy answer..please dont forget to rate :)
Memory capacity
Yes it should. I would remove all of the contents on card and save them then reformat the card and check to see if the full space is available. If not there is freeware available to restore these things to correct amount. If it cannot be done then the card has an issue and needs to be replaced.
When I insert a dvd in the slot it does not read the dvd however cd is displayed. What may be the reason?
-cd corrupted ( try clean the disc with cleaner. If you don't have it then try using perfume(with alcohol). I'm also have try many time using my BOSS perfume. Is alright.
-dvd player have problem( try clean with cd cleaner )
-disc dvd is empty (or damage). Right click to DVD ROM .Choose properties, and see what capacity for that dvd. If it have zero use and full capacity is not zero, that mean dvd disc that is still zero.
I have purchased DVD 123. After 3 installations I was forced to abandon the program because of installation limitations. I often upgrade or reformat my hard drive as I try different drivers and other...
yes you can copy origanal dvd's to a blank 4.7 gb disc
theres only a few discs that can not be copied eg sony you will need the following software
1) any dvd
2) clone dvd
3) nero burning software
or you can buy the following software
dvd fab its around the fifty quid mark but it will let you copy any disc including sony discs
which are the hardest to clone and the results are fantastic and its simple to use
hoped this helped
When I use a Maxell DVD, everytime I enter the disc, it automatically formats the disc again. The record digital reading also does not look the same as with other discs.
U using DVD+R DVD disc?Not possible the DVD+R DVD disc to be reformat,it only can be burn and written data's into the disc only one time to the DVD+R disc.Are u using DVD+RW DVD this disc can be reformat,but DVD+RW DVD disc doesn't reformat by itself.It can't.The DVD+RW DVD disc data's only can be over written with new data's putting into it.
2answers
Can I play Blu Ray discs on a DVD-224 player?
No. Blu Ray media requires a different device technology provided only by Blu Ray players. It will not play on a DVD player.
Recently, my player will intermittantly show a blank blue screen on certain DVD's, not all of them. There were no scratches I could see on the discs. I bought a new DVD player and it did the same thing...
You are getting drop out of data from the DVDs, depending on the quality of the orinal DVD discs, some times they will deteriorate after few years. Look for any scratches on the lable side of the DVD. On some discs lable side where the reflective coating may not be protected well, if it is damaged it cannot be read.
Asking to format full disc
The simple trick is to put a disc into desktop DVD recorder. If Your DVD will be recognized, then copy all content to another DVD or camera. I've seen it before. Must work. Sincerely.
MY NEW DVD BURNER WONT BURN ONTO DISCS
I beleive that you may need to reinstall the drive and update the drivers,
if youve got XP OS then you will need SP2 updates also.
the blank dvds are x16 speed and blank cdr are x52 speed.
the format you are going to write in determines the disk you need the use,DVD blanks are 4,7GB and CDR and 700MB
Check your help section to better understand Neros functionality and the many formats it is capable of....
Once you figure it out then make a HOW TO DO STUFF FILE
Store the documents here for future reference.....
Hope this helps,please rate me thanks
Blu ray disc
BlueRay is a new high capacity disk storage media system. It has a much greater capacity than any of the other systems.
The blue laser light is of a much narrower beam width and higher speed computing technology, it is possible to now have a much greater capacity for data speed handling and data capacity.
All the new High Definition movies are coming out on BlueRay disks. To play these disks, a BlueRay player will be necessary.
The technology is moving at a faster rate all the time. In about five years, there is a newer system coming out that will even be ahead of the BlueRay. They are working on a new generation high speed plug-in memory modules at the consumer level. These modules will have their own full function microcontroler built in. The data will be using internal fiber optical pathways instead of metal conductive pathways. These will be much farther ahead than anything we have now.
Jerry G.
Jerry G.
Top Memorex Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
