Battery Sharkshttps://www.batterysharks.com > mpv5_b12-35_x2
The Hoveround MPV5 wheelchair requires 2 batteries - SP12-35 NB (12 V 35 AH). Please note that you need to use all existing cables and hardware from your ...
US$110.98 · In stock
This part is for an Invacare power wheelchair with TRSS. This is a tilt and or recline single switch for actuator control. A search on the Invacare website shows an active part number and no price. A search of e_bay shows pricing between 50 and 150 dollars. This switch is easy to replace. plug the black "Lego " block into the power source, the 2 pin Anderson plug into the actuator and the Molex into the limit switch. You may need to switch the plug polarity of the 2 pin output to the actuator to get it to go in the right direction. The part was used on MkIV and MkV and some MKVI systems and should be readily available on line. Hope this helps.
Either way will work when charging the batteries and it wion't hurt the chair either way. If you can stand to have the lights scrolling all night when you charge the chair then leave it on If not turn the power off Your charger will tell you when its finished by turning the yellow light green. Hope this helps
