Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
If "everything" works and your microwave just stopped heating, the problem might be with the internal door switches, the high voltage circuitry, or the circuit board or quite probalby your magnetron is dead. If you don't have the technical knowledge to repair microwaves, you should take it to a repair service for diagnostics.
Check internal fuse. If it's ok, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. Diagnostics and repair might be quite complicates so better you take it to a repair service. You have some interesting Youtube video tutorials to repair a microwave
I see you want to know how to repair your Frigidaire microwave, model# PLMV169DCD. Repairs on microwaves are typically not a do it yourself repair. I suggest contacting your local authorized technician for further assistance. They have been trained specifically on your appliance and will know exactly how to repair your microwave. Hope this is helpful.
All cautions I have seen regarding repairing a microwave is to have it serviced by a repair technician authorized to repair one's make of microwave oven.
I suggest you find a repair business in your area which is authorized to repair Sharp brand microwaves. You then can make a telephone call to explain the problem with your microwave and ask if it can be repaired and even find out an estimate of the repair cost before you decide to take the microwave in for repair. You can then decide if you wish to pay for the repair or purchase a good quality replacement.
Note: If you wish to research microwave oven brands which may make good replacements, Consumer Reports magazine provides reliable reviews. This is the link to the 2017 Consumer Reports Microwave Buying Guide: https://www.consumerreports.org/cro/microwave-ovens/buying-guide
I am a librarian by profession. We receive questions about reliable appliance review sources all the time.
Note: Safety advice I have read regarding microwave oven repair is to have a microwave oven repaired only by an authorized repair technician. It is not do-it-yourself work.
Any repair might not be worth the cost compared to purchasing a new replacement. A microwave repair technician authorized to work on Tappan microwave ovens will be able to evaluate what is causing the loud noise and give you an estimate of the repair costs.
Note: If you find you need to replace your microwave oven, please be sure the old microwave oven is sent to electronics recycling.
This website should have all the information necessary for you to fix your microwave. http://www.partselect.com/microwave+no-heat+repair.htm Be careful if you try to repair your microwave yourself and make sure to disable the proper parts before attempting a repair so you don't have a risk of being shocked. Keep in mind that often times microwave repairs cost more than buying a new microwave, so you should just consider buying a new one, if a complicated repair is necessary.
