My engine light keeps flashing ,,, i had it read and it is reading random miss fire..i changed the plugs , plug cables , rotor and cap,,,it is still reading random miss fire ...what next..
Cables and connectors to and from the ignition module.
Coil assembly.
Ignition module or crankshaft position sensor.
Have you reset the engine computer since you did the work? Some models have a small wire going to a connector attached to the positive battery cable that supplies memory power to the engine computer. If you disconnect this and leave it off for ten minutes or so, the computer will clear all of the engine codes. (If you don't see the separate wire, disconnecting the battery will do the same thing.) It will also reset its engine parameter information to factory default, so check your owner's manual for what to do after changing the battery to "retrain" the computer for your engine and driving habits.
