LG 32LC7D Television Logo
Anonymous Posted on Jun 06, 2017
I have a 2008 LCD TV (model = LG32LC7D-AB )and a 2013 DVBT/IP Set Top Box. After periods of use, my STB and TV loses HDMI synch and the TV goes to black. It often takes a power cycle of the STB to get everything back to normal. I've got the STB running on two other LG TVs and I don't have this problem. Would the fact the TV is so old and perhaps using a different HDMI version be a problem? Or are there other thoughts as to what can be going wrong? Cheers Sandra
3 Related Answers
Anonymous
  • Posted on Mar 20, 2008
SOURCE: lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Anonymous
  • 197 Answers
  • Posted on Jun 07, 2009
SOURCE: tv won't turn on - power SUPPLY OK
bad main pcb
Jaime Hernandez
  • 2351 Answers
  • Posted on Sep 24, 2010
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
1helpful
I have started setup for hd cable. Am connected to hdmi and have picture and sound but am unable to change channels. What do I need to do.
With the HDTV set for an HDMI Input that matches the HDMI Jack that you've connected to the cable HD STB (set-top-box or "converter"), use the cable STB remote to change channels on the STB - not the TV.
You can not change channels of the STB with your TV remote. You may however, be able to program your STB remote to operate your TV. Most will allow you to power the TV on / off; volume up / down / mute; change input (HDMI1 / HDMI2 / ANT / Composite / etc.) and even some of the more complex functions as well. Contact your cable company for more details.
How do you tune alba b660 STB without remote
unless there are buttons on the front, you will need a remote to do this, sorry
Box is not detecting channels
Thanks for the answers and explanations. I'm going to purchase a Linux STB on switchonshop and now I'm trying to figure out all the things concerning TV boxes, applications, installation. It's not that difficult as far as I understand but still I have to pay attention to many aspects.
Tv turns on picture shows for 3 seconds then screen turns solid green. Sound is present even when screen is green.
I had the same problem on my Sharp LC-32SB24U Liquid Crystal TV. When I couldn't find any solutions on this site, I looked elsewhere on the internet. I found two credible leads.
First, supposedly, this is caused by a known problem with Verizon FIOS. Apparently, there's a problem that Verizon knows about that has to do with the signal between the Set Top Box (STB) and the TV, via the HDMI cable. Other posters on other sites said that the problem is more common with the 7100 series STB's and that the problem is not as rampant on the 6400 series STB's. (Mine is a 7200 series STB.) I have not called Verizon yet, but other posters said that Verizon just says that you'll have to use a set of basic red, yellow, and white cables, versus and HDMI cable, until Verizon gets the bugs out of the system.
The other credible lead revolves around unplugging the TV for two minutes and then plugging it back in. Simple.
Here's what I did, and it worked!
I unplugged the STB and let it sit for 5 minutes. Then, when I plugged the STB back in and powered itself back up, my problem was solved! (Before I did this, I tried just unplugging my HDMI cable to rely solely on my basic connector cables, but that didn't do anything for me.)
Good luck all!
Green color of screen
Good luck all!
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
