Question about Dell Latitude D830 Notebook
Need users manual for Conexant HDA D330 MDC modem
I am trying to to find the AT Command Set for this modem so that I can add the individual commands for Error Correct, Data Compression and the Bell 103 Standard (if available). to the existing Initialization Command in a software program to communicate with a security panel. I have a Dell Latitude D830 and get no help from Dell support.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 194 Answers
6ya staff
SOURCE:
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
Nov 10, 2013 | Computers & Internet
Safe mode windows
if you didn't set the default administrator password, then you should
have been able to pass. However, if you remember that password, then please typed it in. Else you either need to download a third-party software that does the job, or you do the following instead.
Restart the PC, hold down F8 once you enter the Windows Boot Menu choose Safe Mode with Command Prompt, and now type in the following:
net user root /add
net localgroup Administrators root /add
net localgroup Users root /delete
The first command adds a new user called "root", the second command adds that user to the Administrators group and the third command removes the user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at a Password Reset Disk Step-by-Step Guide.
Direct link: http://www.itknowledge24.com/
Sep 27, 2013 | Dell Latitude D830 Notebook
I need command log(DTE & DCE) of FAX class 2 modem
i am searching for pc suite for my motorola W 230 please me what i shall do.
Mar 22, 2010 | Conexant chipset 56K V.92 PCI Data/Fax...
I set shutdown time at 10 pm by using crontab but server shutdown at 1800 or 6 pm . I am using LINUX CentOS
Hi
Try using ttps://launchpad.net/gpoweroff also the other way to set auto shut down is
Also another way is
A simpler way is to add the appropriate shutdown command to the /etc/profile file (as root):
Open a terminal window and su to root:
[user@localhost ~]$ su
Password: (enter root password here)
This example will open /etc/profile in the kate text editor:
[root@localhost user] # kate /etc/profile
Add the following command to the end of the file:
shutdown -h hh:mm
Replace hh:mm with the time at which you want the computer to shutdown automatically each day
The -h option tells shutdown to turn the
computer off (halt).
For more information on the shutdown
command open a terminal window and enter:
man shutdown
Remember, the man command is your friend.
With it you can get information on nearly
any command available in your Linux system
Let me know if this helps
Mar 17, 2010 | Fujitsu Siemens Siemens PRIMERGY RX300...
Im having ethernet problems with my inspiron E1505 dell laptop. after a reboot the computer no longer recognizes ethernet plugged into it. the cable has been tested and works fine. the drivers (Conexant...
Your ethernet card is not working and it seems to be damaged so if your laptop in under warranty so replace it free from the service center. Otherwise they will take charges for this replacement.
Regards
Ashish Kumar
Feb 02, 2010 | Dell Inspiron E1505 Notebook
I have d-link 560e modem and i want at command to disable line hangup inorder to open other application after the connection is up
If the software that you are using with the modem does not have the ability to set the modem to autoanswer you will need to configure the modem manually. You will have to use Hyperterminal to enter the command into the modem's memory.
(if you do not have Hyperterminal installed please add it by going to Control Panel > Add/Remove Programs > Windows Setup > Communications > Details...)
Have the modem connected to your computer and ensure that it is working fine. Go to:
Start > Programs > Accessories > [Communications] > Hyperterminal .... Hyperterm.exe > name the connection "modem" > Connect Using... Select COM3 or COM4 (on whichever port the modem was assigned to) > Bits per second 9600 > OK.
After that try typing ATZ command and press ENTER (you may not see what you are typing). The response from the modem should be OK.
Apply the following command:
ATS0=3
Now write the new settings into the modem's memory by typing the following command and pressing Enter:
AT&W
The response should be "OK"
The modem will now be set to auto-answer after 3 rings.
Jun 21, 2009 | D-Link DU-562M Modem
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Driver Problem
Jan 28, 2009 | HP Pavilion dv2000t Notebook
Computer cant connect to internet
set up a new internet connection and configure the modem which yuou are having
Feb 07, 2008 | Conexant All 56K Modems: Amigo V.92...
Dell Latitude D830 Notebook Logo
1,071 people viewed this question
Ekse
Clive
Clive
Alun Cox
