Re: what cld cause sharp 5316 indicating an open...
NO! 500 copies cannot spoil a copier.It should last for 100s of thousands of copies.Try opening and closing the front door.That will sometimes reset some error codes
Thermistor open detected. Thermistor defect
MCU PWB defect
Fusing section connector contact
failure
Power supply failure
Fusing unit not installed
on
Check the harness and the
connector of the thermistor and
the MCU.
Clear the self diag display with
SIM 14.
It appears there is a paper jammed in the thermistor area, remove that piece and check thermistor. Clean it or check its connection for open circuit and rectify.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
An error code of H2 om a sharp 5316 indicates an open thermistor.A thermistor is a small electronic device that regulates temperature.You will need to call a copier technician.An Ar5316 operates at 16 copies per minute.Good Luck!
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse.
Aloha,
Bill Monroe
there might be some dirt on thermistor above the heater upper roller pls check and clean the fuser unit then use simulation 14 to reset the machine enter simulation by presssing #,interrupt,c,interrupt in sequence display is then off, then no. 14 then start key h2 disappears ok
