Sparkle Power FSP460-601U (FSP460601UB) Power Supply Logo
Anonymous Posted on Aug 13, 2013
UMAX livewire 700w smps (80% efficiency) i bought
UMAX livewire 700w smps (80% efficiency) i bought it today, played crysis 3 on high settings and my pc suddenly shuts down and when i tried to restart, it didnt. i had to switch off the power and turn it on again and then i tried to start my pc, the smps burnt with sparkling. MOBO: ASRock 990FX fatality Processor: AMD FX 8350 @4ghz RAM: Corsair Vengeance 8GB x 2 (1600mhz) GFX CARD: Palit 550Ti 1GB
What is a sodium vapor lamp?
There are two types of sodium vapor lamps, the low pressure sodium and the high pressure sodium. Both types are very efficient, in fact they are the most efficient bulbs made today. The sodium vapor cost around 80$ the bulb and the ballast and a spare bulb will cost you around 30 dollars.
Aug 21, 2012 • Fish
I got Sony Xplod XM-ZR704 700W 4/3/2-Channel Car Stereo Amplifier and 12" sub. it play good for continuous 2 hours but after that starts tripping and goes on off. i checked all wires and connections.
Amp is probably over heating. Make sure the ohm load of speaker is good for that amp. This amp is not really built to handle a bridged 2 ohm load. Make sure ground wire is clean and tight to the body chassis.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Error in play crysis 2 unsupported videos card
It looks like your card is below the minimum requirements for this game. You will need a faster (newer) card to run this game. It's not surprising, as many of these shooters have very high system requirements, and your 3-4 year old card probably wouldn't cut it even if it did work.
The good news is that a new card will run it faster and look better. Since your old card is PCIE 2.0 compatible, make sure that your new one is also 2.0 compatible. (Unless you know for sure that the mainboard supports PCIE 2.1) PCIE 2.0 cards will work on 2.1 mainboards, but the opposite is not true.
Here is the link to Crysis 2's minimum specs:
http://www.ea.com/crysis-2/blog/pc-specs
1helpful
Hey PLEASE HELP me!!! i really need to upgrade my pc for crysis 2 and other great titles coming out,it can play bioshock 2 maxed on 1080p with around 60fps but it can only handle crysis 1 on low/a bit...
to play the latest games i think you might need to upgrade your video card and your processor\
note: crysis 1 has a very high requirement.... because of the game engine it use.....
akuma_ryu21
dont forget to rate!
Driver don't work with Palit 9600 GT 1GB
this can be an cooling issue with 2 graphics cards in your system or it could be caused by your SMPS, it should be 700w or above to handle such a system efficiently.
Crysis screen cut off
make the system setting to default and restart the game it should work. have the same problem. but it is just temporary. post the solution if you get one,
My Umax AstraPix now only records in RAW.
After posting this query, I discovered that the camera has 3 resolution setting - Normal, High Quality (HQ) and super high quality (SHQ). Though this is a simple camera, SHQ records to RAW, the other two to JPEG. I didn't find a way of opening or converting the RAW files, but will stick to HQ in future. If anyone knows where I can find a manual for the Umax AstraPix 430, I'd be very pleased to hear. Umas don't seem to have one on their site.
2answers
New battery on used phone won't charge
The battery might be bad you can go and have someone check the battery at any electronic store with a voltage meter.
Unable to play the PC game Crysis
AlanChong20, update you're video casr software. The radeon 9200 last update is listed at this link.
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
The date for the upgrade is Nov. 15, 2006 No more driver update are being made.
If you're game still gives you the same error try lowering the game graphics detail settings. If set to high, bring them down to medium. It very possible you're card does not have enough memory to play the game. The 9200 is a older card. It may be time to upgrade.
Mike
I can't play Prey on my new fancy card...
You can try and install the latest patch to the game here:
http://downloads.gamezone.com/demos/d20976.htm
Also make sure you have the latest drivers for your video card.
Hope this helps!
Top Sparkle Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sparkle Computer and Internet Expert? Answer questions, earn points and help others
