It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
run your comp in safe mode, if still not working, run 32 bit dell diagnostic using teh drivers disc, test touchpad, if still not working replace palmrest
Check the box that says Activate Presentation Mode
But I don't think that will make your screen brighter, if its still dark then look for the function hot key to turn up the brightness on your screen. Its usually something like - hold the "fn" key and press the up arrow several times.
1. Reseat the battery. 2. Remove All External Components 3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris. 4. Remove All External Components 5. Try a known-good battery in the system, if available.
I found many references to this issue but I am not sure which may apply
to your problem. Here is a set of steps to follow from another site:
(Assumes Vista and Realtek)
Open Vista’s Control Panel (Window | Control Panel)
Open the Realtek Audio Manager (not “Sound”)
In the navigation bar in the far right, there is a little yellow
folder icon. It is just below “Device advanced settings” and above
“ANALOG”. Click the folder icon.
Click “Disable front panel jack detection” so that a yellow check
mark shows up. Hit “OK”, and close the Realtek HD Audio Manager. That
should re-enable the sound.
