Greetings . . . Lesley - they don't exist. Seriously. Apple has decided to store the OS on a 'hidden' partition in case a restore is needed. Also, if the drive is replaced the EFI has an option to download and install the OS from the internet. There are various schemes (unsupported by Apple) to build a bootable CDROM from data on that partition. The other approach that you can use is to purchase Apple MacOS Server of the same version. This will come on a DVD. I'm considering this option myself . . . .
Good Luck
Mark
SOURCE: How do I use iCloud on the new OS X Mountain Lion?
All you do is go into "System Preferences" and then click on "iCloud". From there you will be able to activate your account and proceed.
Please note that you will have to set up an @me.com email address from Apple. Without this you will not be able to sync between devices like you wish to do.
SOURCE: Apple OS X Mountain Lion and Facebook help please
Unfortunately Apple does not have Facebook integration for Mountain Lion yet. It is expected to be released in the fall or so.
You are able to integrate with Twitter however, if you use that social media site.
SOURCE: Apple OS X 10.8 Mountain Lion error 1008:9-5000
You should already have read/write access to your own Application
Support folder. If you are referring to the /Library/Application Support
folder, repairing permissions should set the proper permissions on the
folder, but probably not the contents (you really shouldn't change
permissions on system files and folders). Trying to move or change
permissions on the contents of an entire folder may also fail if there
are items in there that you don't have access for, such as those owned
by another user (check the permissions of the specific folder that you
are trying to copy to).
