Whirlpool GHW9100L Front Load Washer Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shock or stablizer drum
Shock or stablizer bar for the drum has come loose
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on May 14, 2009
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
900884
Points
3465
Power of the wall socket first. Unscrew the shock or 'damper' completely as it is known, noting position, head tail. Test it, it should not be pumping very loose, if so you should replace it. Otherwise just put it back in and tighten the bolts well.
2helpful
2answers
I have done shocks bilsteins front sway bar eibach brakes diff gasket and cover performance stering stablizer all tie rods all 4 bALLJOINTS NEW 20 INCH RIMS AND BRAND NEW TIRES FUTERA GOODYEARS 3 DIF...
I can think of two things not easily seen that can cause a banging when hitting small bumps;
The sway bar end links could be loose or broken.
The rear shock bolts, the lower bolt that holds the shock onto the rear axle, I've seen that mounting hole down there get enlarged, allowing the shock bolt to move about when hitting small bumps, causing a banging sound.
Check those two things out.
2answers
Sounds like a loose part when going over a bump smething in the front suspension
another catch 22 question,ask a local mechanic to have a drive and see what he says ,it could be anything from a shock absorber to a bush ,or a marble in the ashtray ,or even a lost spanner under the bonnet thats dropped inside somewhere ,now where has my screwdriver gone??
2answers
2answers
When speed reaches 60 to 80 kms car feels like driving on washboard road
What you are feeling is wheel hop. One of you tires is seriously out of balance and the shock absorber is no good. Have both chk 'd Good luck, Ned.
2answers
It like its a shock but they are new
Break caliper pins are worn and rattling .
1helpful
Shake at 55 mph just aligned need diagram of parts for 99wrangler
Replace Steering Damper. Looks like a shock absorber by your stabilizer bar. Not that hard to do with right tools.
1helpful
Broken shock and drum/seal leak
Power off the wall mains. Open up the machine panel to look interiors. See if any springs or shocks (known as dampers) have broken or come off. The dampers should not slide in & out freely, if they're defective, replace. Tighten all loose wires, which may have come loose, future probs, so you dont have to open up again.
Next level your machine, front legs way up, means your machine is tilting towards you. Then adjust accordingly so that u cannot shake the machine with both your hands. Lock the nuts, only the fronts legs are adjustable, for most machines. (will get back to u)
1helpful
2answers
Front end of my 87 jeep cherokee shakes bad when i hit a bump
May check your ball joints and tie rods. Also could be your shocks.
Does it seem like its more shaking on the left or right? or even?
Oil leaking from shock
I would not drive it like that. Have them come and get it. I used to work for Gabriel Shocks at the Manufacturing Plant in Oklahoma and can Tell you that you Could loose Control Driving it that way. Warranty will cover it.
Shaking wheels
It's something in your steering components or you tires. I've seen both. If your tires are pretty good, it could be your steering stablizer. It's like a shock asorber for you steering system. There also maybe some components wearing out in your steering system too though casuing the stablizer to wear out or unable to to asorb the shock from the bump.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
