SOURCE: GE Profile Spacemaker® XL1800 Microwave Oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: ge spacemaker xl1800 microwave
F3 on a GE microwave indicates a defective keypad.
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it.
At power-up, the display should flash or show a text message. If not, a key may be stuck due to a foreign substance or a defective keypad.
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board.
To check that, see our critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
SOURCE: GE XL1800 Microwave Night Light Inoperative
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
