It sounds like the thermostat is "stuck closed". Try unplugging the cooler, MAKE SURE ALL POWER HAS BEEN DISCONECTED. Remove thermostat cover with thermostat on it. Carefully pull one of the wires spade connectors off the thermostat. Insulate the end of the wire you disconected with electrical tape. Now plug the cooler back in. If the compressor stays off the thermostat is the problem. Let me know if that helps. I know of a common replacement cold controll for that unit:)
