Cars & Trucks Logo
Richard Posted on Aug 11, 2013
Mercedes clk 200 petrol 1999.guys I really need help quickly please. Only brought the car yesterday and already it's a goner. Driving home it was very sluggish. this morning again sluggish. TThisafternoon car will turn over but no power at all. Put my foot right down and the Rev counter will only go to 1500 revs and that's it. Please help.
Justin Fossum
Level 1:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 11, 2013
Justin Fossum
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
4813
Points
54
If it runs good in park or at idle but is slugish when you try to accelerate it is likely a fuel issue. I would start with a new fuel filter. When you press on the gas you need more fuel pressure and if the pump cant get more through the clogged filter you will get that. If it runs bad even at idle it is likely a spark issue and needs new plugs and wires. I would give it a good tune up - oil change, spark plugs (platinum or iridium), plug wires, air filter, fuel filter, PCV Valve and see how she runs after that.
5 Related Answers
Anonymous
  • Posted on Jun 27, 2008
SOURCE: Intermittent high revving!
Throttle position sensor.
Anonymous
  • 36 Answers
  • Posted on May 23, 2009
SOURCE: engine speed will not rev over 4000rpm
Sounds like a fuel filter issue. If the filter is clogged or is getting to the point where it's going to be clogged badly the amount of fuel going to the engine will be restricted. This would cause your stated problem. Theoretically there isn't much of a need to go over 4000 rpm unless you are racing with the car but I think most bimmer owners can understand where you are coming from:) As far as the 1993, I'd check all your intake piping and vacuum lines and make sure there are no leaks whatsoever. An easy way to check is to have the car running and spray carb cleaner on the intake piping and such and see if your revs increase, if they do you've got a leak. Hope this helps! I'd be glad to help with any other questions you might have a please don't forget to rate me.
Richard Jordaan
  • 10 Answers
  • Posted on Jul 18, 2008
SOURCE: bmw 316 e36
change your fuel filter if it does'nt work check that your fuel pressure is ok if not check that all the plugs on your air intake is all good and pluged in properly
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 18, 2009
SOURCE: Renault laguna 2. rev counter
renault ---dealer only
Anonymous
  • 43 Answers
  • Posted on Apr 08, 2009
SOURCE: need to find battery location: 1999 Mercedes CLK 320
Hi, The battery is located in the trunk, under the trunk mat.
2answers
Location of fuel cutoff/reset switch clk 230 K
MB doesn't use a reset switch (AKA Inertia switch) for the fuel pump
Partition open on my clk 350 mercedes, top won't go down
your crank and no start issue is likely caused by a failing crankshaft position sensor. they usually fail when at high temps like driving and when engine cools off they are OK again, it will fail while driving as it gets worse.
My 1999 clk 320 suddenly will not shift out of 3rd gear, its been going good for 184000 miles and all service has been done by a mercedes mechanic
sounds like the transmission is in limp home mode where it won't shift out of second gear. this is a fail safe mode. If the check engine light is on too then its probably not seeing one of the speed sensors in the transmission. Just need to have the codes pulled in the transmission control module.
2answers
Help my roof wont go down only had the car a week
electicly fuse blown,mechanickly the hinges/joints dry/seized
1helpful
Computor keeps indicating blown bulbs but there all working on clk 200
the module that senses this problem is defective, a common problem in this car, the new part is about $400
1helpful
Mercedes clk 320 04 reg door lock n/s will not close is this home repair job or do i need special tools
open the door handle from inside your car like your getting out and hold it up then take a skrew driver and where the hindge is on the door yhas a little lever that pushes down it is stuck so pry it back up while your still holding te handle up
5helpful
4answers
Hi, I have a Mercedes CLK 320 and the radio doesn't work.
I purchased a MB CLK 320 and set the radio frequency and successfully put the freq in memory, however, the radio blinks tthe freq. Is this normal or do I have to enter another key to stop the radio from blinking?
Ed
Massachusetts
1999 Mercedes CLK radio antenna
look at antenna wires make sure every thing is in contact.if all is good.sound like problems in the sound amplifier.in radio.
2helpful
Need to find battery location: 1999 Mercedes CLK 320
Need new battery for clk 230 cabriolet x reg
If you want to go with the same style battery, or if that's what is reccomended, just call your nearest mercedes dealership, ask for service and explain your situation, and ask if there is an alternative.
hope this helps
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
