Contributor
- Posted on Apr 18, 2009
Re: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
- Unplug the machine.
- Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
- Unscrew the visible screw holding the plastic in place near the drain hose and filter
- If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
- Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
- Unscrew two screws in the drawer area.
- Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
- Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
- Pull the seal away from the metal front panel, then close the door
- Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
- Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
- There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
- There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
- Order replacement and reassmble in the opposite order
wont drain, will spin with no water but will not spin with water load
does this apply to the top loader LG wave force this is the ine I am talking about
