SOURCE: NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
SOURCE: i cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
SOURCE: Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
SOURCE: Network wont show up on any Wireless Network List
Probably during the reset process the Radio got disabled
