SOURCE: Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
SOURCE: Compaq Presario V6000, keeps rebooting, blank screen,
If your pc reboots just after post my first place to look is to reseat the hard drive and see if that makes a difference. If it doesnt you could try and repairing your windows operating system or doing a system restore. If the os loads sucessfully then i would say you had a corrupt boot file maybe from a virus or a failing hard drive. I hope this helps
SOURCE: Compaq Presario V6000, keeps rebooting, blank screen, and no post
I had same problem described above. I also just let it try to start over and over until it finally did. Hasn't happened again since, touch wood. The only thing different before it happened was I had the main battery out to transport it. Could be weak cmos battery perhaps.
Always back up your data!
SOURCE: I have a Compaq nc6000 that would not boot up. I
Sounds like your display panel is bad or it's another symptom of a mother board flex problem at the Maxim chip
