Who makes this starter if i type in delta starter # 500-84-102-0072 I get no hits. How can I troubleshoot if its the relay transformer or heaters
This problem has to be solved by process of elimination first make sure the voltage used is the correct voltage the next step is to disconnect the motor wires from the starter and turn on the power if the starter engages u have a bad motor if breaker trips starter or power cable is shorted a direct on line 220 volts rated at 20 amps motor starter will work just fine or contactor and overload relay at 20 amps 220 volts ( GE, allan bradly,merlin gerin,legrand are some brand manufactures
