Sounds like the volume control on zone 2 is your culpret. You should set up zone 2 to have a "fixed" output instead of "variable" it's in zone 2/3 setup. whats happening is you are overloading the volume control from the zone volume on the receiver and getting feedback to the receiver and shorting it out. What you do is put zone 2 to fixed output. set the vol control to 3/4 then adjust the vol to relatively loud and exit out of settings. this will be your max volume setting. Now, on to your problem.Unplug the receiver. There is an internal fuse that could have blown, not to likely but it's possible. You have to take the top off the receiver with a #1 phillips or a T10 torx they vary. It's about 7 screws, pop off the top and look from front to back, you will see 1 or 2 fuses near the AC plug port. Sometimes they are gray or white and you cannot visibly tell if it's bad. If you have a multimeter, set it tone resistance. Then put your leads on either side of the fuse, if you hear tone the fuse is ok. If not check your leads by touching them together and you will hear tone then test again. If you don't have tone, your fuse is bad. Radio Shack should stock the fuse you need. If you don't already know this, there are 2 Power switches for your unit. Front of receiver bottom left corner "Master Power" and normal Power switch "Main Power" check them both. If your fuses are good and power is good, you have bad transistors internally and it needs to go to service. check
www.yamahausa.com support and service, and you can find the closest authorized service center to send it to. If you mail it out directly to the service center rather than taking it to a dealer, you will save some money and get it back faster. Lastly, pull your zone 2 volume control and look for black marks on it or white chalky substance. "oxidation". If you don't mind spending a little money on the system, hardwire the speakers thru and replace the volume control with an IR receiver. If you could control the zone from the zone by pointing the remote at the volume control you had an IR vol control. You really didn't need the vol part. Xantech or Proficient make good IR receivers that aren't too expensive and will keep this from happening again. If you need any more help, I am a Yamaha Dealer, let me know where your located and I can send you to a good service center. Just post a comment and I'll get you the info you need. Hope this helps
when i turn on the zone 2 control to raise the volume it says (volume fix) I dont know if its broken or what?
