Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
TV shuts self off
The TV power light comes on when I turn on the TV, but the screen stays blank and it makes a fizzling/crackling sound for about 5 seconds, then shuts itself off? Can I somehow repair this myself or am I better off looking for a new TV? Thanks
RCA model# D52W20
  • djprophet7 Apr 08, 2009
    i try to turn on tv and it makes a fizzle sound and then does not turn on . Is it the power supply or what
  • chanele22 Apr 13, 2009
    I have had my TV now for 5 years and never had one problem with it but now I have the same problem as you. It turns on, fizzles and shuts off. I can smell a faint smell of electrical burning from the back left corner. I'm thinking it may be time to get a new tv!
Did you get your problem fixed?
Posted on May 24, 2009
6ya staff
SOURCE:
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Turn on tv, only stays on 5 seconds, shuts off. crackling sound in back
Capacitors need replacement on the power supply. It is being over drawn for voltage. I would repair before turning it on again as this is hard on your tv.
Thank you and best of luck!
Jun 14, 2011 | Televison & Video
Tv turns on but makes an electric cracking sound and shuts off another one turns on then the screen wigs out and turns off with the power light flashing
Try to unplug tv from the power source for 2-5 minutes and if still have the crackling sound it means the tv needs to be fix. So check your tv's warranty and call the tv's manufacturer to have it fix or replaced.
Sep 09, 2010 | Philips 32PT6441/37 32" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
309 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
