You're very welcome and feel free to ask any question in that area - I should be able to help, also please don't forget to rate my response.
Thanx-DynamiYou're very welcome and feel free to ask any question in that area - I should be able to help, also please don't forget to rate my response.
Thanx-Dynami
You can't post conmments that contain an email address.
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
turn on the ignition. if the yellow gets power with the key on, and no power with the key off, it connects to the yellow on the radio. Yellow on the radio is for memory power, to remember your presets and clock.
All aftermarket radios now are all the same when it comes to wiring colors.
black is always common, or ground for all aftermarket radios.
Pull the radio out, tape off all wires but yellow, red and black. Twist red/ yellow together and attach to positive 12 volt, attach black wire to negative 12 volts. Turn on radio and see if it comes out of protect mode. If it does, you will have to troubleshoot all of the speaker wires to find a short.
Battery is yellow Accessory is white/red Ground is black Illumination is red/black Power antenna is yellow/white LF speaker +blue/green - grey/black RF speaker +red/green - brown/black LR speaker +blue/yellow -grey/white RR speaker+red/yellow -brown/white
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
http://www.tehnomagazin.com/Auto-radio-car-connector/KENWOOD-Car-Radio-Wiring-Connector.htm for the deck
1) Remove the ashtray and the two outermost screws exposed in the ashtray cavity. 2) Remove two screws from each side of the dash console. 3) Remove the climate control knobs. 4) Unclip the trim bezel and remove. 5) Remove four screws securing the car stereo to the dash. 6) Pull car stereo from console releasing antenna and connectors.
Constant 12V+
Red
Switched 12V+
Orange/Yellow
Ground
Black
Illumination
Red/Green
Dimmer
Green/Red
Antenna
Driver's Pillar
Front Speakers
6 1/2" Doors
Left Front (+)
Orange
Left Front (-)
Black
Right Front (+)
Gray
Right Front (-)
Green
Rear Speakers
4" Tail Gate
Left Rear (+)
White
Left Rear (-)
Red
Right Rear (+)
Yellow
Right Rear (-)
Blue
did u check the fuse in the back of the radio?did you check the radio fuse in your car? Do you have the yellow battery memory wire hooked up? Is the black ground wire connected
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Thank you for a quick answer
