SOURCE: Dell Latitude D620 - Screen shows boot up, but then goes blank
Here are some easy things that can sometimes resolve this
problem:
1) Sometimes there can be a static buildup on the mother board. Power
off, remove the battery, remove the power cord and hold the power button in the
on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive
and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Hope this helps and have a super day!
Ron
SOURCE: Network Boot
hi,
i have dell c400 laptop, its to much simple to install xp
first you just take out hdd from laptop
plug in tht hdd in desktop pc by external usb box
now u just start windows 98 setup in it
when it started first format ur drive then install it
when windows 98 setup files copies to 100%. machine need to restart
u just plug out the hdd and plug in back to laptop
now the setup will remain start in ur laptop and when the installation complete u just upgrade ur windows from 98 to xp by intalling xp from external drive on OPERATING SYSTEM OF 98 WINDOWS
NOW WAT U SAY???
ITS TO MUCH SIMPLE just try once
SOURCE: Dell latitude d610 dark screen
there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly you should go to service and need to be changed INVERTER.
pls rate
SOURCE: my dell laptop latitude d610 have no audio sound
Go to the DELL support page
http://support.euro.dell.com/support
Click drivers & download
enter your system type and model
You will then be presented with all the drivers for your D610.
Download the Sigmatel driver in the Audio section.
Save the file then run to install the driver.
SOURCE: DOWNLOAD OF DELL LATITUDE D610 SOUND DRIVERS
You can download the DELL D610 driver from the link below. You can also download all other drivers and utilities from this link.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=LAT_PNT_PM_D610
