If your Bosch Sensixx B22L iron suddenly stopped heating and generating steam, it is possible that the mainboard has failed or there is a security mode activated. Unfortunately, resetting the security mode or accessing diagnostics requires specific knowledge and tools.
If you have already checked the voltages and resistance of the valve, pump, iron heater, and steam heater, and they are all within normal range, it may be best to bring the iron to a qualified technician for further diagnosis and repair.
You can try contacting Bosch customer support or looking for a service manual for your specific model online. A service manual may contain information on troubleshooting steps, circuit diagrams, and resetting security modes.
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
HI!
I HAVE AN
Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL.
I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK.
THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
see the instruction from your manual: Check the owner's manual for your iron to learn the manufacturer's
suggestions for cleaning, what water to use, and storage tips. Soft-water systems add minerals that can harm an electric steam iron and
your clothes so don't fill the iron with softened water. Instead, use
filtered or distilled water. 2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open. God bless you
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick. I hope this helps you. If it does, please rate my suggestion!
