The R230 printer is compatible with the SSC utility and also has an access hatch in the rear that allows easy access to the waste ink tube.
While you could take the printer to a service centre the chances are high that they would be unable to source the necessary parts to replace the original pads, and also the cost would be in excess of 100 GBP or more for labour, etc.
So, opting for a self-reset and external waste ink tank like a Printer Potty would be a far more cost effective move.
For the reset, this screen cast covers the basics for setting up compatibility mode in Windows Vista or 7. If you're using Windows XP you can skip ahead to the part where it shows you how to use the SSC utility itself.
Note: Windows 8 is not supported, in which case you've be looking at the WICReset utility and a key purchase to complete the reset. Still worth it though.
SOURCE: Parts inside your printer are at the end of their service life. S
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
SOURCE: Parts inside your printer are at the end of their service life. See your printer documentation
I FOUND IT! I KNOW HOW TO FIX:
This saved my printer:
Part 2:
Good luck guys!!
SOURCE: Parts inside your printer are near the end of their service life.
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
