Re: I can't get my head around how to manually wind my...
You are not supposed to wind the watch, in simply winds itself with the motion of your wrist. A weighted wheel located in the back of the watch winds a spring that powers the second hand. The minute and hour is power by quartz and a battery.
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
You can get instructions for your watch from the Fossil web site.
Go
to "fossil.com", go to the bottom of the page and you will see a menu,
click on "customer care", and then look under "Product Info" on the
left and you will see "watch instructions"
Click on this and a
list of diagrams and watch descriptions will appear,Download the file
that is suitable for your watch.
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes).
To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
I have a Fossil Twist ME1011, basically the same idea behind the one you have. What happens is there is a weighted third-circle that is in the back of the watch behind the battery (you can't see it) that spins a spring (the spring is the bottom seethrough part that ISN"T moving!) the spring then moved the UPPER seethrough part, which in turn spins the second hand!
IF the second hand stops working, carefully take the back off the watch and you'll see the weighted third-circle that I was talking about. It should spin, and in the middle there is a tiny flat head screw. The screw can get loose, so gently tighten it and the second hand should work again!
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust. This solution wrks for most of the makes. If this doesb't work - submit the make, model and all the writings on watch caseback.
i think it's explained on the first page of your manual. first u turn the crown clockwise in position 3 to set the day (you have to turn it 24 hrs evey time to change one day). When this is done, you can set the date with the crown in position 2 and turn counter clockwise.
i hope this answers your question
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement). You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly. So, do as follows: 1) Push the crown in, 2) Lay the watch down on flat surface and push on setting lever point, 3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
