If the battery is good then you need to change the memory ram.. that usually happens when the ram goes bad...tekgods.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
SOURCE: My Acer Aspire 5100 wont start up correctly
I had the same problem after running an update to my Norton anti-virus software. When booting the laptop, press F2 to go to the setup menu. One of the options allows you to change the order that is searched when booting up. I moved the boot from hard drive to the last option, allowing it to boot from a network first (which it doesn't find), then from a portable device second (which it doesn't find), and finally from the hard drive. When I boot up, after it doesn't find the first two options, it boots from the hard drive with no problem.
SOURCE: my acer travelmate will not boot up, please help
Well I have the same problem, I think it is a BIOS problem because after the acer screen it says Windows did not start succesfully. I saw start Windows normally but it has that "blink of an eye flash" as well, then it goes back and tries to boot up again. Maybe take it to a shop to get fixed.
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
