LG Express Cool Turbo GR T542G Stopped cooling down all lights working but not keeping cold. I took back off freezer and left off overnight turned back on and pipes were cooling but the fan is not working. Should it automatically come on or will it kick in at a certain temp reached??
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
SOURCE: GE GSS22 refrig wont get cold, freezer does.
Hi, it's possible you have a defrost problem, to know if you have a defrost problem, you should unplug/disconnect refrigerator, remove your produce, leave doors open, for faster defrost, clean and leave unplug/disconnected for about hour, be cautious you will get excessive water from defrosting. let freezer defrost completely, then plug/connect refrigerator, let it work/run for an hour, if it's o/k, put back your produce, if it work good/ o/k for 3 to 4 days and start doing the same thing, you got a defrost problem, defrost problems are caused when excessive ice build up on your evaporator, two things could cause a defrost problem. (1) excessive moisture/ hot air entering refrigerator, hot days,hot foods, regular opening, to close heat source, range/ oven. in cases like that, cleaning of refrigerator will normally solve that problem. (2) faulty defrost heaters, defrost thermostat , located in back of freezer side, you will have to remove shelves and back panel, to get access to it,also check your defrost timer and speed of fan, but first disconnect refrigerator, clean and try , before changing any parts. it could just be excessive moisture. always remember to disconnect your refrigerator before attempting any repairs, let me know what happened, then i could tell you exactly what's problem. good luck
SOURCE: freezer works fine, fridge cool not cold.
if the freezer is freezing and the fan working in the freezer and the fan at the compressor is working and you have no frost build up on the back wall of the freezer caused from a defrost problem -then turn your controls back to the middle. one of the controls is a thermostat control and the other control is merely an air diverter from the freezer to the refrigerator. if you close this diverter down too much (by putting it on 9)it will leave most of the air in the freezer.
bottom line if the freezer is working properly and freezing good all the time then the refrigerator should be ok as well unless you have diverted most air to the freezer. allow 24 hours after you have changed the settings.
you can feel air blowing in the back of the refrigerator at the top next to the freezer and can adjust the diverter control and feel the difference it makes. most of the time the control you use is labeled freezer and if you put both controls on 9 then your freezer will be the coldest but the refrigerator won't get as much air. the thermostat control can be left at 5 or higher (this is the control that turns the refrigerator off) but leave the other control at 5
if this doesn't work you have probably got problems with your freezer also and may not know it yet.
SOURCE: the fridge door was left open overnight and doesnt cool
the turbo cool function is for rapid cooling, when first switching on after defrosting or moving unit,it will switch off automatically when near your set temperature.(+5C)
SOURCE: I have acquired an lg
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
heatman101
