Performed a rebuild of a pool motor with bad bearings. Tested motor and shaft spins smooth. When I put the new seal and impeller back on and hand tighten, the shaft becomes difficult to turn. Is this normal?
NO, should have just a little resistance, you might have a hayward and the o-ring sticks to the impeller shaft and must be removed. OR you have the rotor bearings installed wrong, this too will cause improper shaft clearance.. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
SOURCE: 1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
SOURCE: Impeller tightens on Aqua-Flo Series A brass pool pump
Thank you for posting your question here on Fixya.com.
There is no spacer. The impeller's internal nut and the shaft's shoulder set the spacing. The most likely problem is either the spring portion of the seal is not fully seated into the pump housing or the ceramic portion not fully seated into the impeller. You should also be sure you removed ALL of the old seal and parts. Many people leave the ceramic's boot in place and then the new seal seat will not seal properly.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Testimonial: "Thanks for the prompt response. You solved my problem! The spring seal was not seated all the way but it was not obvious to me - maybe a 64th of an inch made the difference."
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Yes, the seal has been leaking and it needs to be replaced; probably the motor bearings too.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
