SOURCE: Code on the dehumidifier flashes the code "CH
That is the error for a bad sensor assembly. This is about $30 from a few sources.
As an example (I have no idea how close this may be to you)
http://www.appliancefactoryparts.com/search/partinfo.php?partsid=282871
It requires a bit of work to replace. Most of that just getting everything apart. Maybe an hour or two if you do it. If you aren't handy with a screwdriver any shop can do this as well.
SOURCE: Error message CH 24.
We;ve managed to clear this error, at least for the last 5 days. Remove the bucket, and reach up behind the front panel where there is a filter- ours was covered in dust. After cleaning this off, and resetting the machine (by pulling the electric plug out and re-inserting), the error went away.
Your mileage may vary.
SOURCE: LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
