I have a roper gas dryer. The Timer stopped working at the same time the heating element seemed to stop aswell. Are they Related? Is the Timer not working causing the dryer to not work or is the heater making the timer not work? any help would be great as to were to start my search thanks for some reason it says my dryer is not a valid product so I am gonna put the product number here. rgx4635eq1
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
