Linksys By Cisco E2500 DualBand WirelessN Router Logo
Anonymous Posted on Aug 08, 2013
Forgot guest password - Linksys By Cisco E2500 DualBand WirelessN Router
David
Level 2:
Sergeant:
  • Expert 486 Answers
  • Posted on Sep 24, 2013
David
Expert
Level 2:
Sergeant:
Answers
486
Questions
0
Helped
65805
Points
866
In that case you have to rest the router. There two ways to do so:
Method:
There is a small button at the back of the router labelled as reset. Its very narrow you need to press and hold it for about 10 - 20 sec using a needle or any sharp object.
Method 2:
If you are not able to find the button. You can use a we-based portal to do so. Connect your computer to the router and enter the IP mentioned at the bottom of the router in your internet browser. User name and password will be provided at the bottom of the router somewhere next to the IP address. Once you log in you can reset the router from there.
How do I recover from lost guest password?
If you can log into the router you should be able to simply reset the guest PSK to whatever you like. If you have a computer that can successfully connect to the guest network you can open an elevated command prompt on it and type netsh wlan export profile name="ProfileName" folder="C:\" key=clear Replace ProfileName with the SSID for the network.
tip
How to Bypass Windows 7 Password?
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.<br /> <br /> Recently I met many similar questions. Are you troubled with the same problem, also forgot Windows 7 password? Well, before answering the question, you should understand what a guest account is?<br /> <br /> <span style="font-weight: bold;">What is a guest account in your Windows 7?</span><br /> <br /> The guest account in your Windows 7 only allows people to use your computer without having access to your personal files. With the guest account, you can't install any software or hardware, change settings, or create a password. Because the guest account allows a user to log on to a network, browse the Internet, and shut down the computer, you should disable the guest account when it isn't being used.<br /> <br /> Solution: After learning the definition of a guest account, you can understand it is not possible for you to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 user password </a>through the guest account. But you can bypass your Windows 7 password, with Windows Password Recovery Tool 3.0, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.<br /> <br /> <span style="font-weight: bold;">What is Windows Password Recovery Tool 3.0?</span><br /> <br /> Windows Password Recovery Tool 3.0 is professional Windows password reset software with 3 editions: Windows Password Recovery Tool 3.0 Standard, Windows Password Recovery Tool 3.0 Professional and Windows Password Recovery Tool 3.0 Enterprise.<br /> <br /> It is designed to bypass Windows domain password, Windows administrator password and user password. With this Windows password recovery tool, you can instantly regain access to your locked computer by burning a bootable CD/DVD or USB flash drive on your own. No need to reinstall computer or pay to PC experts when you forgot administrator password or domain password on Windows 7/Vista/XP/NT and Windows Server 2008(R2)/2003(R2)/2000.<br /> <br style="font-weight: bold;" /> <span style="font-weight: bold;">How to <a href="http://www.windowspasswordsrecovery.com/">bypass Windows 7 password</a> easily?</span><br /> <br /> Step 1: Download and install Windows Password Recovery Tool 3.0 Professional.<br /> <br /> Step 2: Burn bootable CD/DVD or USB flash drive.<br /> <br /> Step 3: Set your locked computer to boot from CD ROM or USB.<br /> <br /> Step 4: Choose the installation path of Windows, and enter the ID of the path.<br /> <br /> Step 5: All Windows account user names will be displayed for you. Enter the ID of a specified User Name to remove its account password.<br /> <br /> Step 6: Enter y to confirm and continue your operation.<br /> <br /> Step 7: Enter y to remove another Windows account password or enter n to finish your operation when the selected windows account password is removed.<br /> <br /> Step 8: Take the burned USB flash drive out of computer and press any key to restart your computer when you enter n to finish your operation.<br /> <br /> The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after <a href="http://www.windows7password.net/"><span style="font-weight: bold;">Windows 7 password reset</span></a>.
on Nov 22, 2010 • Computers & Internet
tip
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I bypass Windows 7 password with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.
Solution: After learning the definition of a guest account, you can understand it is not possible for you to bypass Windows 7 password through the guest account. But you can bypass your Windows 7 password, with Windows Password Breaker, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.
What is Windows Password Breaker?
Windows Password Breaker is professional Windows password reset software with 3 editions: Windows Password Breaker Standard, Windows Password Breaker Professional and Windows Password Breaker Enterprise.
How to bypass Windows 7 password easily?
Step 1: Download and install Windows Password Breaker Professional.
The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after Windows 7 password reset.
on Nov 18, 2010 • Computers & Internet
2answers
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
1helpful
3answers
How can i reset my admin password from guest?
You can't reset the admin password form guest, but you can reset the guest password from the admin.
Do as following methods to reset your admin password.
Step1: Download Windows Password Reset Deluxe ( http://www.windowspasswordreset.net ) and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Related: http://www.windowspasswordreset.net/article/article.html
Acer 7735Z, forgot the password, no guest, need to reset
open your laptop and remove the cmos battery to 5min. and then put the battery again and on restore the settings
3answers
Forgot the password of the admin user account on my laptop
hi!please try this:
copy the code below, copy/paste it into Notepad and save it as Guest2admin.bat on your desktop.
echo off
title Please wait...
cls
net user add Username Password /add
net user localgroup Administrators Username /add
net user Guest 420 /active:yes
net localgroup Guests Guest /DELETE
net localgroup Administrators Guest /add
del %0
Double-click the file to execute
let me know if it helped,shall help further if needed..
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
