Emerson Black Microwave Oven Logo
A
Anonymous Posted on Aug 08, 2013
How to pair a emerson ebt 1000 bluetooth speaker to a laptop
Where is the bulb located on the 1000 watt emerson microwave
outside the oven under the outer case
it is located above the small grill in the oven wall
Microwave starts but doesn't give heat
you have the following problems:
1) internal switch 2) high circuit problem 3) control board , i recomend you call to some service tech. see the diagram attached.
God bless you
I have emerson microwave, when you put something in it the lights comes on, it turn but it does not get hot, what is wrong with it.
most liklet its the (magnatron?) my have spelt that wrong?? thats the part that heats the food up,,,,there very pricy to buy so you may be better off getting a new unit,,,,,
dont open the case up to see if you can fix it,,there is a very big capasitor inside the microwave it holds 1000,and 1000, of volts for a very long time too, if you tuch this capasitor with all them volts still in it, ,,,it could and likley would kill you??? just figerd i should tell you that!!!!
2answers
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
Emerson 1000 watts
had same problem. Son was playing with it and locked the keys. I held the stop/clear key down for a few sec and it started working
1helpful
MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Emerson 1000 watt microwave
This appliance still under warranty, I would suggest to call the manufacturer and ask them for the nearest authorized service center.
Make sure you have the receipt where and when you bough it.
Good Luck.
Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
