Zebra 110Xi III Plus Thermal Printer Logo
Posted on Apr 04, 2009
Printer status offline needs to be online
The printer wont print any labels because status is set offline for some reason. needs to be online and data flashlight is not blinking there is no connection between printer and computer. need immediate assisance.
A
Anonymous
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
2answers
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
My printer brother DCP-J315W status is offline, how do I change to online?
This one is really easy if you know what're you doing. Just go to your printer in control panel to bring up the print dialog. Go to printer at the top of page, drop down the menu and uncheck use printer off line. That should fix your problem.
If you still have issues with this particular model, you can always download this neat manual. It really helped me a lot. Good luck!
11helpful
6answers
Epson printer offline
In this section, we provide some practical ways to resolve the Epson Printer Offline Issue. Simply follow the mentioned teachings carefully and fix this error on your own.
If your Epson printer is displaying an offline message, it means that there is some connectivity problem between the Epson printer and PC. ... Incorrect printer settings where your printer is not set as "Default Printer" may make your printer go offline. An outdated printer driver may stop your printer from functioning.
In the same way, How do I put my Epson printer back online?
Verify The Printer Connection
Update Epson Printer Driver
Check Printing Status
Restart The Print Spooler Service
Add A Second Printer
Hopefully, now you can surely Resolve this issue. I Hope, this content is valuable for you to solve the Epson printer says offline windows 10.
Epson Printer Not Connecting to WiFi
Epson Printer is Not Responding
To change print status "offline" to "online
Go to devices and printers to see if your printer is set to default. Make sure the printer cables are plugged in tight. Offline means it is not getting a signal . In Case You Still Having Problem Then Follow Us For On : Brother Printer Support
3helpful
2answers
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
My hp 2360 wont print, green light keeps on blinking, it says printer offline on the printer status bar
Make sure that cable to printer is attached and if printer still shows offline then in control panel for the printers make sure that you right click and choose Use Printer Online
What the flashing light means
The Power light can flash for several reasons:
? The printer cover is open.
? The printer is out of paper.
? A problem exists with the printer, such as a paper jam or a problem with a print
cartridge.
For information
2answers
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
