I have power, but it wont run. I was useing it,and shut it off for a second.when I put it back on I got nothing???
Just got done fixing our Heritage II model 2HD, it had a dirty safety switch. Both the hose attachment and the roller housing depress a plunger to close the switch, thus sending AC to the motor brushes. You might want to try pushing this in and out repeatedly with your thumb, power removed of course, in an attempt to make better contact. If this works to restore power to the motor, it'll be just a short time before the problem repeats itself. You'll have to remove the switch to give it a thorough cleaning. I didn't have any contact cleaner handy, so I wound up using WD40. Hope this helps. Kevin H.
It might be a bad cord you can get it looked at
and they can probably fix it
SOURCE: Kirby Legend 2 Vaccum cleaner
Did you ever find a use and care book for this vacuum. I have one I could scan for you.
SOURCE: how do you put on the attachment hose?
The Heritage II Legend...First you make sure that the machine is unplugged from any outlet,. Now, raise your height adjust to the highest level. Next you will need to turn your belt lifter on the front of the nozzel to the right as far as you can. Now flip the hinged light cover up, and turn the latch that holds down the head to the left. Your nozzle is now released. Now take the hose and roll it on to the bar from the front to the back, make sure it is aligned and then turn the latch to the right locking the hose, and you are ready to kirby it up! Hope this fixesya! Let me know, Thanks, Rene (the Vacuum Doctor)
SOURCE: Kirby G3A Attempts to start but wont run
http://www.fixya.com/support/t4287180-need_replace_power_supply_cord
Here is the answer you are probably looking for
