check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
That sounds like the reed valve sticking or dirty. You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Johndeere 10w-30 in cooler weather and 5w30 in warmer weather. Any auto parts store has small engine oil. They may have a better idea when you go to purchase your oil for your particular climate.
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
group size battery for onan 4000 watt
