Arris DCT6200 DTV Receiver Logo
A
Anonymous Posted on Aug 07, 2013
Dvr error codes
What is code ACC
Dish Network VIP 722K DVR error Code message 207
Call Dish and check if your service is active, then have them send a programming authorization hit to your 722.
tip
DISH VIP612 Remote Code Scan
DISH Solo DVR VIP612 Remote Code Scan
Would you like to autoscan program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your TV, VCR, receiver, or stereo?
To auto-program device codes into your Dish Solo DVR VIP 612 Universal Remote by searching for the code, follow these steps:
  1. Turn the device you would like to control on.
  2. Press and hold the mode (TV, VCR, or AUX) button until all the other buttons light up, and then let go. The mode button will flash.
  3. FOR AUX MODE ONLY - Press 0 for a 2nd TV, 1 for a 2nd VCR, or 2 for a receiver, amplifier or tuner. Then press the STAR (*) button.
  4. Press POWER to put your remote into scan mode.
  5. Press the UP or DOWN ARROW repeatedly until your device turns off. Each arrow press tries the next code your remote knows for your selected device type. When your device turns off, you have found a compatible code. When the remote runs out of codes to try, the device will flash rapidly eight times.
  6. Press POUND (#). The mode button will flash three times as it stores the found code.
  7. Turn the device back on and try some of the other buttons to make sure they work. If all functions work, your remote has been successfully programmed.
  8. If the code didn't work, repeat this scanning procedure to find a more compatible code. When your device turns off during your next scan, press the arrow key again until the device turns back on to signify you have found the next compatible code.
Your device's remote control codes for your TV, VCR, or receiver are now programmed into your DISH Solo DVR ViP 612 remote control.
(The other way to program your DISH Solo DVR ViP 612 remote control is to look at the tables in back of the user manual, and enter the code directly.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 • Televison & Video
E11 error code fios motorola box
Eb 11 - Invalid unit address / Resettable only at factory / Replace the DCT
Here's a site with a list of fault codes:
How to use Motorola DVR Boot Error Codes
3helpful
2answers
How do I get the check engine codes? 2003 Durango
There's two ways to retrieve the code. 1. Put the key in the ignition and turn the key to the "ACC" position, then back to "Off", then ACC, and Off, then ACC. (Off, ACC, Off, ACC, Off, ACC) You don't have to do it fast, just hold each position for about 1 second. On the final "ACC" position, the trouble code should flash in the digital odometer. (P#####) When you have the code, you can Google it and you'll see what the code means. 2. Use your scan tool (Or use Autozone's) and plug into the OBDII port under the dashboard and pull the code. They should have a book that tells you what the code means.
1helpful
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
1helpful
2answers
Pioneer DVR-K17RS ATA ACER CODE=39
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
2answers
TV CODE
The code for mine is 0842. It's a 32" Magnavox MF338B LCD HDTV being used with a Comcast Digital DVR.
2helpful
2answers
Hitachi DZMV550A Error Code
PLEASE RESOLVED THE ERRO CODE NUMBER 2881.
Top Arris Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
