At the end of the wash cycle there is a large amount of water left in the tub. I can hear water being pumped out during the normal wash cycle. Any ideas, I'm thinking the timer?
If you are saying that after the washer has finished you are left with wet cloths and water left standing in the tub ,then your pump is broken or as was my case I opened the back and removed the pump only to find a small piece of wicker that had come off my laundry basket . It was keeping the pump from turning .I removed it put everything back in place and saved over $380.00 . I hope this helps good luck .
The First comment here was absolutely right! Thanks! save a lot of $$$. In my case there was a piece of rubber that was keeping the propeler of the pump motor from spining, that's why the water won't drain.
Just experienced this myself. I have the 4000 series from 1999 and it has two water pumps that remove water from the washer. Inside the rubber hose, there is a small plastic filter that was plugged from water calcification over the years. The main hose was clear other than that. It is tough to get parts for these older washers so I removed the filter completely and now everything works great.
