2005 Kymco Stryker 125 Logo
Posted on Apr 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My son's 2005 Kymco TGB 50cc scotter hit a good
My son's 2005 Kymco TGB 50cc, 101S Off Road Sports Scooter hit a good sized pot hole. What appears to be a breather tube of some kind dropped off. It's varies in size from about 3/4 inch diameter to just over 1 inch, ends up being about a foot long, but it connects to three places. One hooks to the carb, where do the other two go? Hope you can help. Ric (below it's not a Stryker-it's a smaller scooter but not listed)
  • Anonymous Mar 16, 2014
    how to derestrict tgb delivery 50cc
tombones
Level 3:
  • Master 3,567 Answers
  • Posted on Apr 04, 2009
tombones
Master
Level 3:
Answers
3567
Questions
5
Helped
2101183
Points
15260
Normally, one goes to the carb, one to the gearbox and one to the battery. What sounds really weird is the diameter of the hoses. Three quarter and one inch diameter? Normally 1/4" to 3/8".
Hope this helps!
Please rate this solution. Thanks locjaw69!
2answers
Do you know the engine type for 2017 tgb r125x please and or any performance parts for this scooter thanks
This is all I could find hope it helps. TGB R125X Specs
The TGB R125X model is a Scooter bike manufactured by TGB . In this version sold from year 2008 , the dry weight is 118.0 kg (260.1 pounds) and it is equiped with a Single cylinder, four-stroke motor. The engine produces a maximum peak output power of and a maximum torque of . With this drive-train, the TGB R125X is capable of reaching a maximum top speed of . Regarding the chassis characteristics, responsible for road holding, handling behaviour and ride confort, the TGB R125X have a frame with front suspension being and in the rear suspension it is equiped with . Stock tire sizes are 130/60-13 on the front, and 130/60-13 on the rear. As for stopping power, the TGB R125X braking system includes Single disc size at the front and Single disc size at the rear.
TGB R125X General Information Brand TGB Model TGB R125X Year Year Category Scooter Factory Warranty (Years / miles) TGB R125X Dimensions, Aerodynamics and weight Frame type Seat details Wheelbase Length 1,896 mm (74.6 inches) Width 670 mm (26.4 inches) Height 1,125 mm (44.3 inches) Seat Height Alternate Seat Height Ground Clearance Trail size Wheels details Front Tyres - Rims dimensions Rear Tyres - Rims dimensions Front brakes Single disc Rear brakes Single disc Front Brakes Dimensions - Disc Dimensions Rear Brakes Dimensions - Disc Dimensions Curb Weight (including fluids) Dry Weight 118.0 kg (260.1 pounds) Front Percentage of Weight Rear Percentage of Weight Weight-Power Output Ratio : Fuel Tank Capacity 6.80 litres (1.80 gallons) Reserve Fuel Capacity Carrying Details and Capacity Front Suspension Front Suspension Travel Rear Suspension Rear Suspension Travel
TGB R125X Engine and Transmission Technical Data Engine type - Number of cylinders Single cylinder, four-stroke Engine details Fuel system Engine size - Displacement - Engine capacity 124.00 ccm (7.57 cubic inches) Bore x Stroke 52.4 x 57.2 mm (2.1 x 2.3 inches) Compression Ratio Number of valves per cylinder Camshaft Valvetrain Configuration Maximum power - Output - Horsepower Maximum torque Engine Maximum RPM Cooling system Air Lubrication system Engine oil capacity Exhaust system Gearbox Automatic Transmission type, final drive ratio Belt Clutch type Driveline TGB R125X Performance Top Speed Acceleration 0 to 100 km/h (0 to 62 mph) Acceleration 0 to 400m (1/4 mile) Recuperation 60 to 140 km/h in highest gear Fuel Consumption - MPG - Economy - Efficiency CO2 emissions Emissions TGB R125X Electrical Systems, Ignition and Equipment Ignition Type C.D.I. Electrical Details Starter Type Instruments Lights
2answers
I have a 50cc scooter does the engine need to be running for the head lights to work
hi Kevin.
my son has a 50cc kymco plus a 50cc piagio and both of them need the engine running for the head lights to work.
so it could be yours is the same.
Nov 18, 2017 • Motorcycles
1helpful
How to derestrict the CDI of a 50cc TGB Bullet RS. Model 2013 or 2014
derestrict the CDI of a 50cc TGB Bullet Anon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ScooterCommunity
How to replace the cdi box on your scooter with performance cdi box
How to derestrict 50cc Scooter TuningMatters com
Kymco super 8 50cc will not star
dead battery or a fuse gone ! try turning on indicators , horn , lights ! does the side stand or brake lever have a stop switch on them ? P...
Tgb 101s 50cc won't start
Does the starter turn? Or does it not kick over? Post some more info for detailed help. Check the basics battery, fuel , oil.
1helpful
My 2005 50cc kymco cobra racer scooter does not start
i have fire and new cdi ran find for 2 days but hard to start now it will not start
TGB 101S 2006 50cc - no spark
new plugs first, put problem a bad coil
Tgb 101S - no spark
did you try another plug maybe the plug is dead or check fuses there might be a blown fuse or a burnt fusable link
Top Kymco Experts
Arnie Burke
Arnie Burke
littlewheel
Are you a Kymco Expert? Answer questions, earn points and help others
