Sungale ID706WTA Tablet Logo
Anonymous Posted on Nov 22, 2017
My Sungale ID706WTA tablet is crashing. Every time I power on the tablet the error notification keeps popping up saying the Launcher has unexpectedly stopped. I have to keep hitting force close a billion times and it will not go away. I cannot get past it in order to go to my settings to do a factory data reset. what do I do?
anthony alagon
Level 2:
Habit-Forming:
  • Expert 170 Answers
  • Posted on Nov 22, 2017
anthony alagon
Expert
Level 2:
Habit-Forming:
Answers
170
Questions
0
Helped
37872
Points
461
Factory Data reset / Hard reset
  • Switch off the tablet.
  • Press and hold the Power and the Volume Up keys.
  • When you see the logo, release only the Power key. ...
  • From the Android recovery menu select one by one:
  • - wipe data/factory reset.
  • - Yes -- delete all user data.
  • - reboot system now.
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
5answers
I am trying to get on my tablet and a message keeps popping up saying that the launcher stopped working. Can you tell me what is wrong.
Well, a core application manager software (the one that helps you find and start apps when you click is broken). Please give a description of Tablet make/model(such as Apple iPad 5, Dell...) and OS name (IOS or Android 2.3 or so) This will help direct you appropriately..
Tablet keeps restarting
the software problem may be, try re install the os
Ok I am having trouble with my Android Craig tablet. There's a message keeps popping up on my screen an it's blocking me from getting to my stuff. The message says "The application Launcher (process...
Phone is getting an error message: "Unfortunately Launcher Has Stopped."
Unfortunately Launcher Has Stopped:
  1. Swipe your finger from top to bottom on the screen to view the notification panel
  2. Touch the Settings or
  3. Touch Apps
  4. Touch Menu or
  5. Touch Reset App Preferences
  6. Touch Reset Apps
  7. Swipe from right to left 2-3 times to show the ALL list.
    (For device running on Android 6.0.X touch Menu then Show system)
  8. Touch Launcher
    (For device running on Android 6.0.X touch Stock Android then Storage)
  9. Touch Clear Data
  10. Touch OK
  11. Power Cycle Phone
  12. Test phone
hope this isn't clear as mud. :) and helps you
Keep getting pop- up that says sorry the process.android.acore has stopped unexpectedly.please try again
seems like the firmware is crashed. have u tried backing up and doing a soft reset ? 2_24_2014_2_30_41_pm.jpg
A13 tablet launcher not working due to density
I just did something exactly like this on my phone. Here's what I did for solving it.
NOTE: you will need access to a PC with internet connection and your problem Device must have access to the internet. You also need access to the PLAY store on both the PC and the problem device. From what I understand from reading your explanation this should not be a problem.
1 - Start your Device as normal and when you get the force close message go to the Report option.2 - Once on the report screen (accept the terms and conditions if they appear) you should be able to pull down the notifications bar.3. On the PC go to the play store (you must log in with the same account as the one in your problem device)4. Search for a different Launcher and install it through the play store on your PC. (I used Zeam Launcher for resolving my issue but I did this on a phone so it might not be available for a tablet. You can search for Launcher and find one that way)
5. The new launcher should automatically start downloading and installing on your problem device. You should be able to see this happening on the notification bar.
6. Once finished, just go back to the main screen. You should get the option of what launcher to use. Select the newly installed launcher. (do no use the default option).
7. Once in the new launcher, go to the density changer application and change it back to the original density.
8. Reboot your tablet and it should now work correctly.
NOTE #2: I did this on a phone. I've never owned a tablet so I'm not 100% sure this will work for you.
Hope this helps solve your problem.
1helpful
Have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Top Sungale Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Sungale Tablet and eReader Expert? Answer questions, earn points and help others
