<span><b>Flash/Upgrade your Firmware using PHOENIX</b><br /><b>THIS TUTORIAL WORKS WITH ANY NOKIA CELLPHONE</b></span>
<span><b><br /></b></span>
<span><b>USE WINDOWS XP.<br />NOT 100% COMPATIBLE forWINDOW 7</b></span>
<span><b>Things you need:</b><br /><b>1. Your NOKIA CELLPHONE with FULL BATTERY.<br />2. Compatibe Nokia USB cable.<br />3. Nokia PC Suite (Version 7.1)<br />4. Phoenix Software </b><b><i>(</i><i>CREDITS TO XXIV_19)</i>.<br /></b><b>5. Latest Firmware from Blue Nokia.<br />6. Desktop/Laptop with internet connection. </b></span>
<b><br /></b>
<span><u><b>STEP 1. </b></u><br /><b>1. </b>Download and install Nokia PC Suite Vesion 7.1 --> </span><a href="http://www.mediafire.com/?uixd3jnn5jg">http://www.mediafire.com/?uixd3jnn5jg</a>
<br />
<span><u><b>STEP 2:</b></u><br /><b>1.</b> Turn off your cp --> remove battery --> look where your cp was manufactured --> note also the RM version & the 7 digit product code <br /><i>(Ex. Made in China, RM-346, Product code - 0576672)</i><br /><br /><b>2. </b>Turn on your cp. Check the firmware installed --> dial *#0000#.<br /><br /><b>3.</b> Download & Install your<b> LATEST FIRMWARE</b> ---> DOWNLOAD HERE -> </span><a href="http://www.blue-nokia.com/index02.html">http://www.blue-nokia.com/index02.html</a> --><span>On Blue Nokia website (upper right screen) <b>choose phonetype</b></span><i>(Ex. select <b>E71</b></i><i>)</i>
<span><i><br /></i></span>
<span><b>- Choose APAC</b> for cellphones made in Asia. <b>If APAC is not available, you can use EMEA. </b><br /><b>- Choose EMEA/MEA</b> if it was made in Europe, the Middle East and Africa<b>.</b><br /><i>[Ex. <b>E71</b> --> </i><i>E71 -1 (RM-346) 500.21.009 v10 (APAC)]</i></span><span></span>
<i><br /></i>
<span><u><b>STEP 3<br /></b></u><b>1.</b> Download Phoenix Software(choose 1 any link is available</span><span>.)</span>
<a href="http://www.mediafire.com/?yi3wo0ymx0m">http://www.mediafire.com/?yi3wo0ymx0m</a><br />
<a href="http://www.mediafire.com/?w1e2whxjpgu9i2s">http://www.mediafire.com/?w1e2whxjpgu9i2s</a>
<br />
<span><b>2.</b> Install Phoenix Software <i><b>(follow my screenshots)</b></i></span>
<span><i><b><br /></b></i></span>
<span><i><b><img src="vhin100889.jpg" /><img src="vhin100889_0.jpg" /><br /></b></i></span>
<br />
<span><b><u>NOTE:</u></b> <i>when APPEAR ERROR ON INSTALLATION --> JUST CLICK <u><b>CONTINUE ANYWAY</b></u></i></span>
<span><i><u><b><br /></b></u></i></span>
<span><i><u><b><img src="vhin100889_1.jpg" /><br /></b></u></i></span>
<span><u><b>STEP 4<br /></b></u><b>1.</b> Open Nokia PC Suite.<br /><br /><b>2.</b> Connect your cp using compatible Nokia USB Cable. <b>Connection type: <u>PC Suite </u></b><br /><br /><b>3.</b> Open Phoenix <br /><br /><i><b>(PLEASE FOLLOW MY SCREENSHOTS!!!)</b></i></span>
<span><i><b><img src="vhin100889_2.jpg" /><img src="vhin100889_3.jpg" /><img src="vhin100889_4.jpg" /><img src="vhin100889_5.jpg" /><img src="vhin100889_6.jpg" /><img src="vhin100889_7.jpg" /><img src="vhin100889_8.jpg" /><img src="vhin100889_9.jpg" /><img src="vhin100889_10.jpg" /><img src="vhin100889_11.jpg" /><img src="vhin100889_12.jpg" /><img src="vhin100889_13.jpg" /><img src="vhin100889_14.jpg" /><br /></b></i></span>
<span><u><b>NOTE:</b></u><i> If you want to change your PRODUCT CODE: Click the <b>box w/ 3 small dots</b> on the RIGHT SIDE of PRODUCT CODE BAR</i><br /></span>
<span><i><img src="vhin100889_15.jpg" /><img src="vhin100889_16.jpg" /><img src="vhin100889_17.jpg" /></i></span>
Not possible, you need a battery charger that suits the battery. If your camera uses AA or AAA batteries then any AA or AAA battery charger is OK otherwise you need to get a Nikon battery charger that suits your battery.
For this check your battery.whether it lock to battery slot correctly or not.
If not just put thick small paper piece on the battery while closing the outer lid.
If battery lock correctly you need to flask your phone(This problem due to virus).
flash(format) resets your security code to 12345
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
as long as the battery you are purchasing is of the correct dimensions to allow it to be fitted correctly ie secured properly and is of a sufficient aprer hour rating to suit your car then go ahead fit it (most auto parts stores will keep you right.)
Select your phone make model and proceed for the download.
As for the battery, maybe the battery is weak that's why it drains fast. Maybe you should just go ahead and replace the battery. Make sure you charge the new battery before you start using it.
when you turn your phone on only the keypad lights up right? or nothing
happens? if nothing happens charge your phone til red led on side
turns off after that please continue to read
its a w980
software problem, very common
the solution is to open
up sony ericsson pc suite then under tools
click "phone repair" and follow the prompts if this fails it means
your battery is dead, try charging it and try again please note this
will restore phone to factory state
