If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
It sounds that there is a direct short circuit in anywhere in circuit board. Most probably, it might be to vertical sweep output section, in Sony TVs. Here you noted that the standby light blinks. Blinking of standby light to Sony TVs are fault indications. Count it, and check this.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
