SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
SOURCE: Whirlpool Duet Washer - Problems with the Spin Cycle
you might want to call whirlpool cause it might be still in warranty
SOURCE: Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
SOURCE: WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
SOURCE: F06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
