SOURCE: device manager shows error in sm bus controler
goto to system devices look for the question mark, right click, and try reinstall the drivers again, this should normally work and reboot your machine and the drivers should be there.
may be the bus driver you are trying to install may not be compatable for your machine, check with the user manual to see what bus derivers you can install
SOURCE: can not get online because of missing drivers for ethernet
do windows update custum scan least get driver for erther net on a cd from anther ok the custum scan then hardware add all
SOURCE: I have hp compact presario v6000.
You have to install the drives again
download from here
Or use your motherboard cd
If an error occurs during the installation make sure to remove the device from the device manager
Reboot
Re-Install the driver
Remember- Don't remove drivers which are related to The Power Options
