hi, your phone might be hanging because u don't have enough memory space on the phone memory, try freeing up some space by deleting some items like media files that is stored on the phone's memory. Hope you know that for the visual radio to work you must connect a headset to the phone to act as the antenna. hope that helps
Actually sir there are a lot of reason why a computer becomes slow..First because of viruses, secondly your computer is very populated with files and applications and your hardware devices cannot accommodate it. But since you're connecting to the internet i know you have a good antivirus..perhaps i recommend you to try this 1. examine your files and application and choose the files you frequently used and not frequently used. 2. delete unwanted files and applications that you already didn't use so that it will free hard disk space and virtual memory of your computer. 3 go to recycle bin and empty it. freeing hard disk space and virtual memory can help your computer perform much faster...Reply to this post if your problem are not solved..Tnx for using fixya..
This means that you need to free up some space in you phone memory or memory card. Access the file manager from the menu and start deleting some of your files there that you dont use anymore. Files would be pictures, sounds or video. This will solved the issue once you free up some space.
you need to delete some of your texts also go to your setting and click auto delete on it will delete the last one everytime you fill up your box so you will never run out of space.
Hello Sir\Ma,
Firstly, your phone may be affected with virus, probably some files or application you have on the phone memory is being affected with virus. and to remove the virus, it is either you connect your phone to a PC that has a strong or updated antivirus using a USB, then scan it for virus, but if no virus is detected, then the slowness is a result of overload.
If you have too much files like heavy music, videos, themes, applications, and picture of a higher bytes on the phone memory or memory card may as well slow down your phone especially if the memory card capacity or size is to higher for the phone to carry. So, you will need to either reduce those files or probably delete then. you can also delete some old message that are not needed so as to free space on the phone memory.
Regards
Yous should delete unwanted files on ur memory card especially on ur phone memory.
Fast solution for that is doing a reset (will delete all phone memory) so, backup ur files first.
Steps:
phone should be OFF. press the * key, numeric 3 keypad & Green call button then press & hold the power button. You should press the keys for 10 to 15 seconds.
Try restarting your computer. If you don't restart
every so often, the cache memory in your computer, which holds
temporary files, can run out of space. You can also go into your system
tools under accessories in the start menu and use the disk cleanup to
get rid of unnecessary and temporary files, or defragment your drive to
rearrange files so the computer maximizes available space.
go to message menu then press options and press settings and come down to other press that and change the memory options to memory card instead of phone memory hope it works
