SOURCE: coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
SOURCE: kitchen aid electric stove does not go on
check the door lock switches on the door lock they get bent out of sdhape real easy
SOURCE: Broiler element comes on on Kitchen Aid KDRP407 on all settings
Have you resolved your oven problem ? If so, what was it ?
I have the same exact thing going on....
Brad
SOURCE: my keys 700gq0 Kitchen aide dryer wont heat and I
Unplug the dryer and the first thing to do is check for the presence of
220 volts at the wall outlet. If you lost one leg of the 220 volts, it
is possible for your dryer to run but there will not be any heat. Once
you verified there is definitely 220 volts at the wall outlet, remove
the rear cover. On the lower right hand side you will see a silver
canister which contains the heating element. Remove the lower two wires
directly from the heating element and check this for continuity. If it
is good, on the left hand side of the same canister they often install a
thermal safety which may have tripped. Do the same test as with the
heating element. Remove the wires and test the thermal safety for
continuity. If this is good, move to the blower housing on the left
side of the exhaust vent and look for a white piece of plastic which has
two wires on it. Remove these two wires and check this item for
continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
