Hello, LSU ERROR on this machine means that the Laser Unit is fauly and needs to be replaced. You can call for a tech or can take the printer to a printer service.
LSU error means a laser failure or a power failure.its just like a problem like a computer getting hang.So in this scenario u need to switch off the machines and restart it after 5 min.
LSU = laser scanning unit. I have a similar problem and i solved it by reseting my printers memory. You must enter tech mode. --> Data setup --> Clear all mem
with an lsu error the paper will get to the cartridge and the laser scanning unit will start charging the transfer drum, at this point the printer realises the laser scanning unit isnt working properly and stops all operation hence the paper stopping at that point, usually this means a replacement lsu which unfortunately isnt deemed a "user serviceable part" contact a service centre armed with this information and your better placed to get a speedy repair
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
