Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
Anonymous Posted on Aug 06, 2013
Adjust carb on a sthil 011 - Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
Plink-plonk
Level 3:
  • Husqvarna Master 1,807 Answers
  • Posted on Aug 06, 2013
Plink-plonk
Husqvarna Master
Level 3:
Answers
1807
Questions
Helped
818156
Points
15648
Adjust the carb using the two tuning screws marked H & L. The other one adjusts the idle speed 'tick over'
I haves Sthil 010 AV chainsaw. It has no carburetor. How do I know which is the right one
Hello, here is the website with the correct part for you:
Stihl 009 010AV 011 AVT Chainsaw Parts
Please rate my answer, thk you.
Nov 15, 2015 • Garden
HOW DO YOU ADJUST CARB ON STHIL CHAIN SAW
start by turning adjustment screws in. turn low speed out one turn and the high side 3/4 turn. start engine and adjust accordingly. the one turn and 3/4 turn are the starting point. saw should start at these settings and then you can fine tune. without knowing your elevation I can't give you the number of turns .
Oct 13, 2014 • Garden
Why does my sthil fs66 weed trimmer run when choke but dies when off
Fuel issue, adjust carb, fuel lines, and or rebuild carb.
Aug 31, 2014 • Garden
Sthil 011 chain saw flooding has new carb
may be new carb but the main thing in flooding is that the float is getting stuck or has crack in it...Or second thing is that the needle valve has a piece of trash dirt causing it to stay open..
Jul 24, 2014 • Garden
Motor runs but blade stops 1" into the wood
Seems like it could be a clutch/drum issue. I have known clutches to break through the threads in the crank shaft so they appear tight but are actually broken. I'd look at the drum assembly to see why the drive to the chain is slipping.
1helpful
Tk carb ? sthil trimmer has 3 adj screws ,how do you adj?
One adjustment screw (probably Phillips-head) is the Idle speed adjustment screw. Turn it in, to increase idle speed (it moves the throttle plate)...turn it out to slow idle speed down. The other 2 screws are the Low mixture screw and the High mixture screw. The L screw is closest to the engine and is used to adjust the engine at IDLE. The H mixture screw is to be adjusted when the engine is at wide-open throttle to get the proper RPM's....not too little and not too much. Here is a tutorial by Zama carburetor reiterating what I have just told you and HOW to go about your adjustment.
http://www.zamacarb.com/tipspage.html
Sep 11, 2011 • Garden
How to rebuild a carbeurator for028 sthil chainsaw and adjusting the ga s valve?
disassemble the carburetor and spray with carb.cleaner.Makesure the small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Nov 27, 2009 • Garden
Filling carb up with fuel
this sounds likke the float is sticking
Sep 08, 2009 • Saws
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
