id not drive any car with trans leaks.
is buying a new box for $3000 , good idea on old 95 car?
really that be end of life for that car, with a bill like that,
more than car is worth , running or not.
nice tortture(sic) test,
learn to respect expensive complex transmissions.
and win.
IMO
who, get it fixed and stop driving it, you are only making it worse.
and more expensive.
Try unplugging it, then wait a few munites,then plug it in again.
If that does not do it, see if the switch has a reset position and they turn it to that point.
hi, HP Officejet 5610 All-In-One InkJet Printerhas few common problems. Such asDriver CD lost,Scanner does not work,Connection problemetc. For find all these software solution just clickhere....
wash cycle is between 10-14 munites. rinse cycle is about 10 munites. pluse time to fill and discharge water from the tub. total time should be about 40-45 munites
When you get to the normal/safe mode screen, select enable VGA. This will boot your computer using the standard 640 x 480 default. Once you are in windows, then you can go into the display properties and change it to a resolution that is compatible with your screen and computer.
